TwinTurbo.NET: Nissan 300ZX forum - Re: Frustation with a cylinder missing
Subject Re: Frustation with a cylinder missing
Posted by txq45 on March 16, 2011 at 5:11 PM
  This message has been viewed 181 times.
In Reply To Frustation with a cylinder missing posted by Daltondak on March 15, 2011 at 09:42 PM
Message If you have the old style Fuel Injectors it's most likely one of them.. ..Do a balance test if you can or ohm them out.
Changed three sets this last month One was on a MINT TT with 58k on it which had 2 bad injectors. Upgraded to the new style using the kit from Z1.
The kit is a easy install,, removing the upper plenum is not so easy on a completely stock engine.
Nistune Dealer
Built Automatics -ECU socketing ECU eprom upgrades
WWW.AAA-HiperformanceAuto.com
